Posted: Wed Jun 24, 2009 12:32 am
the transom height is not the height above water level as quoted by someone above but the height from the bottom of the boat to the top of the transom.. and you measure the motor from the cavitation plate to the inside of the mounting clamp.......
If you have a pod and your boat planes you lift the motor 2 inches for every 6 inches of pod length
I give you this information because I know many of you have modern engines as well and one of the biggest problems with planing hulls is people having he motor too deep ....
If you have a long shaft on a boat intended for a shortshaft you may get very tippy sensitive steering due to the leverage .....
We see all these problems daily here at the Noosa Prop Shop .
