However the engine runs well at higher revs, but when it slows to tick over it tends to die. In particular when slowing down to engage the clutch the engine stalls as soon as the clutch is engaged. Tickle it again and it starts easily. I suspect fuel starvation, so I will whip off the carb and investigate. For early running in I am using 8:1 and the carb has no inlet cowl or trumpet currently fitted. Could this combination make the engine run too weak?
I will refit the exhaust clamp also as per Charles' advice to stop the clutch jumping into gear. It does it all the time, not good when you turn your back to untie the boat
So a bit more tweaking to do
