Re: Another JM magneto resurrected
Posted: Tue Mar 12, 2019 11:03 pm
Fared is the measure of capacitance. A capacitor and condensors is the same thing. Condensor is the old time description. A condensor stores electrical energy and then releases it. If you have 2 6 volt batteries you can join them to create 12volt. ie end to end. + to - to + to -.
I tried a few methods of testing but they didn't work. Personally I've never worried about testing them and only did so as you mentioned it. Good to learn.
Also if you measure the resistance across a condensor your meter will put out a small charge which then can be seen if you change the range to dc volts. Incidentally this is why you should never test the resistance of a car air bag as this small charge can explode the bag!
