Page 2 of 2
Re: SD parts
Posted: Sat May 19, 2018 3:00 pm
by RickUK
Just a comment on re-plating of SD legs - I had two or three done where I requested dull zinc- if 'zinc' only is specified, the end results will be the bight zinc as is seen on modern nuts and bolts etc.
I'm not sure how the dull finish was achieved - it would be a different plating solution to the modern stuff, but plating on non-polished surface would help achieve a matte finish.
Galvanising - whilst still zinc - would tend to leave a heavier deposit, probably with the mottled finish associated with lamp posts and buckets (can you still buy galvanised buckets?)
Re: SD parts
Posted: Sat May 19, 2018 5:13 pm
I've seen a few that look like they could even be dipped in zinc?
Re: SD parts
Posted: Sat May 19, 2018 11:29 pm
Good input Rick. I've been contemplating about what to do re-refinishing of drive tubes. I wouldn't have thought about asking for "dull" zinc. Not sure if l will go down HA's method of replacing tube and if l did would SS plate well or should l stick to steel? Yet to reach a decision.
Jacob, that would still leave me one short though l'm rather partial to the brass bayonet one, not original notwithstanding!
Wasn't Meghan's dress amazing! And l like the Queen's glass backed limo. Was that a Bentley or Roller? I even shed a tear during the ceremony. Don't tell anyone. Sook.
Re: SD parts
Posted: Sat May 19, 2018 11:34 pm
Hugs, at least 2 years ago I posted pictures of a Seagull technical report basically explaining why stainless steel was not suitable for use as drive shaft tubes.
Re: SD parts
Posted: Sat May 19, 2018 11:49 pm
I can't find that post but did find that SS fractures. Good, I'll stay away from it. That will keep the cost down.
Re: SD parts
Posted: Sun May 27, 2018 9:58 pm
by fleetingcontact
I found the post but the attachments are no longer available. Hey Charles, how about you re-post it please?
Re: SD parts
Posted: Tue May 29, 2018 7:28 am
by Nudge
Post up the link to the old post even though the pics are missing Please.
