Page 2 of 4
Re: instructions or Amal Carb
Posted: Fri May 08, 2015 9:26 pm
No, it's a tight interference fit.
From your symptoms is sounds like you have a restriction in the air intake for the emulsion tube (brass component above main jet) connected to the hole in the carb bell mouth.
Posted: Sat May 09, 2015 12:31 am
by flyguy
Thanks again Charles, I think I know where you mean, I'll post a few more photos just to be sure
PS a cotton bud stripped of the cotton is a good fit for most of the inlets, the rough finish cleans out gunk
Posted: Sat May 09, 2015 11:04 pm
by flyguy
I really don't know much so all I can do is ask questions and read up
may I ask what the following 6 do
in ONE I can't see an inlet or outlet, should there be one?
in TWO I can't see an outlet, should there be one?
in Three I can't see an outlet, should there be one?
in Four I can't see an outlet but after taking these photos I discovered it does have an outlet
in Five and Six there are no outlets is this right
Posted: Sun May 10, 2015 3:44 am
by NaughtyBits
1,5 & 6 - no outlets on this model. 2, 3 & 4 spray out with carb cleaner. Follow with wire in 3 & 4, if corrosion present, blow out and respray till your sure it's clean. That brass atomiser (?) sleeve next to 2 (that the main jet screws into) pops out if you push from the plunger & needle side - give that a good clean, too. There's a small rebate/flange (?) inside it, so make sure to press out with an old drill bit or something that fits down into it (about an 1/8" or so). Pushing on the top (of the bit that you can see in the carb throat) can damage it, if you have to use some gentle persuasion.
And be sure to wire out the fuel inlet (banjo side, behind the screen & through the seat that the float needle fits). Blow out and spray with carb cleaner.
Should be good to go after that...
Posted: Sun May 10, 2015 8:31 am
by flyguy
Thank you Naughtybits, I have just redone 2 3 4 with cleaner and 3 and 4 with a wire tooth interdental, they should be clean now
looking round for something to push out the brass atomiser I found this wood handle from an artist's brush its conical and fits inside the atomiser but even after gentle tapping with a hammer it shows no sign of popping out, how hard do you think I can hit it without damage?
Posted: Sun May 10, 2015 4:43 pm
by NaughtyBits
The age-old question :!: I think you'll have an easier time using an old drill bit or an allen key that fits snug inside - a sharp tap should do the trick.
Edit: I should have clarified to use the blank end of a drill bit against the tube, for the reasons pointed out by Charles...
Posted: Sun May 10, 2015 5:24 pm
It sides down into the float chamber, the best way to extract is with a stepped aluminium drift, if damaged it can affect the fuel flow & the emulsion tube is not listed as a separate part in the parts book & it would mean buying a complete new bare carb body, mind you looking at the condition of yours that might best the best idea.
Posted: Sun May 10, 2015 5:44 pm
Charles uk wrote:It sides down into the float chamber, the best way to extract is with a stepped aluminium drift, if damaged it can affect the fuel flow & the emulsion tube is not listed as a separate part in the parts book & it would mean buying a complete new bare carb body, mind you looking at the condition of yours that might best the best idea.
My thoughts exactly, you beat me to it.
I have already tested the paint brush method, and that worked on a non corroded carb.
If you have no success, and have no access to a lathe, I can turn a drift up for you.
Posted: Sun May 10, 2015 7:34 pm
by flyguy
Thanks both, with renewed confidence I gave the brush a harder tap and guess what?
yes the brush snapped inside :shock: I managed to poke out the wood with a cotton bud stick
still no luck in removing the emulsion tube, H-A, thanks, I will take up your kind offer of a Drift if I may. PM on its way
if all else fails can I buy a new bare Carb body? I couldn't see it listed on the AMAL website
Thank you
Steve
Posted: Sun May 10, 2015 8:23 pm
Got your P.M.
I have made you one, and tested it.
P.M. your address and I will pop it in the post.
You can pay me in beer. :lol:
Posted: Sun May 10, 2015 8:27 pm
by flyguy
What kind of beer? :P
thanks you are a star
Posted: Wed May 13, 2015 10:24 am
by flyguy
The Drift arrived this Morning, I put it in place, 4 gentle taps and it was loose, another squirt with WD 40 and I pushed it out.
Charles you were 100% right, the flange was clogged with gunk, I am cleaning it up now with Brasso, the Carb is soaking in Carb cleaner, when the Emulsion tube is glowing I will start on the Carb.
you are amazing, thanks H-A for sending this magic wand
Posted: Wed May 13, 2015 1:12 pm
by flyguy
The Emulsion tube is bright and sparkling, I checked the little hole and its clear too, the "bit" it fits into has been cleaned and polished, I have just put it all back together and after my lunch it's going in the wheely bin
I am sure it will run like it should
fingers crossed
Steve
Posted: Wed May 13, 2015 4:39 pm
by flyguy
It started first pull and ran well for about 10 minutes then the engine revved and cut out, so it is still suffering from fuel starvation I think.
I took out the spark plug and it was dry and slightly white so that means running too lean, following the advice I moved the needle down a notch
it took some starting but when it fired it ran well, I warmed it up and to check for cracks in the head I gave it a good soaking of WD40, no signs of bubbles, no difference in engine sound it seemed fine, after 10 minutes the engine started to race so I tickled it and it came back to life for 30 seconds before cutting out.
Where would you go now if it was yours?
I can't be far away can I :cry:
EDIT. I am wondering about the hole in the side of the emulsion tube, should it line up with anything?
Posted: Wed May 13, 2015 5:16 pm
by flyguy
checking to see what the richer setting did i've had a look at the spark plug again, its tarry
