Siba Recoil Starter for a 40+
Post your wanted adds here
Re: Siba Recoil Starter for a 40+
Can we try & be a little accurate about this subject Gentlemen.
Only the tubular framed Siba recoil was designed for the Villiers ignition motors 102cc & 64cc with a different frame for each style of crankcase, I belive Seagull & John still stock these.
For the Wipac points ignition the following covered flywheel, cast support frame types were used
64cc part no. ACC 12,000
102cc part no. ACC 11,000
No longer available New.
For classic style Seagulls with an engine number starting with E, with the Mk 3 or 4 Wipac CDI the ACC 13,000 with hex support legs was used.
The 125 & 170 were fitted as standard with the ACC 14,000 & a semi enclosed flywheel cover.
The entire QUB range are the only models with the recoil support base cast in as part of the crankcase,
the majority of which use the ACC QB 030.
Which is no longer available New.
