Phil, I popped the flywheel off and measured the coil with a set of digital calipers.
Diameter = 1.7175 inches
= 43.62 mm
Height = 1.237 inches
= 31.42 mm
My flywheel's high point of the cam barely misses the OMC coil by a hair. So, I can see if another model's flywheel had a slightly larger cam, it would be an issue. But...................I have another solution to this issue. Not as clean as the first coil fitting, but would take a very minor modification to the ignition plate.
This is the currently OMC coil fitting using the core and wing laminates as I previously displayed.
The second option **** I have not tried this second option, so I do not know if it will work. I would like to try it in couple of days when I am able to get off of work. This was my back plan if the first did not work****
- You can leave the old Villiers coil and core intact.
- Place the OMC coil on its side with ground and points wire facing up.
- Center the coil from the outer rim of the ignition plate and plenty of distance from the high point of the cam on the fly wheel.
- Drill a small hole on the bottom of the ignition plate. Making sure it is of adequate distance to center the coil from the high point of the cam on the fly wheel and outer rim of the ignition plate.
- Get an appropriate size flat brass head screw, thin washer, and nut to secure the coil to the ignition plate. This is to secure the coil to ignition plate. (Secure it from the top but do not use a washer too large to mash the wires. Secure the screw with the brass nut under the bottom of the ignition plate.
- Clip the wire going the points and condenser and connect it to the green wire/primary windings wire on the OMC coil.
- Ground the black/ground OMC coil wire to the closest wing Laminate. Just like it was displayed in my first OMC coil option. See the first picture in this post.
- *** Make sure you attach your spark plug wire/ high tension lead to the OMC coil spike prior to securing it to the ignition plate. Make sure the coil spike opening is facing the original coil outlet on the ignition plate.
**** Please make sure the coil is far enough so the magnets do rub on it and that it is far enough away the flywheels cam will not rub on it before you drill your hole!! ***
The OMC core on its side like in the pictures is Height = 1.237 inches = 31.42 mm
The height of the coil on its side displayed in the picture is lower than the wing coil laminates and about the same height of the metal housing containing the points and condenser.
Not all models of the Seagulls are the same dimension, so be very careful and measure before your alter your ignition or purchase a coil.
The first option worked for me, but I have SPJ 1964 Forty plus.
I will get back with the finds of the second OMC coil option, when I get a chance, unless someone willing to try it first.*******
Please use common sense, I did this as an experiment to get my Seagull going. Fortunately it worked. I would hate for someone to ruin a fine motor, so if in doubt use original OEM Villiers coils.
Cheers,
David
