40+ 1964 Villiers ignition issue??
cajuncook1
Re: 40+ 1964 Villiers ignition issue??
Post by cajuncook1 »
Well, I was trying to remove the coil and left and right laminates, but experienced difficulty. The back laminate screws were defaced from corrosion and possible previous owner attempts to remove. I tried drilling them out but I don't have a drill press so I was using a hand held drill.
That was a dumb move! I messed up the laminates and the ignition base plate, so a forum buddy from AOMCI is going to sell me a used ignition plate and coil laminates.
Do the coil studs lift up after the nuts have been removed? Why are the back coil laminated screws so fine and difficult to remove? Any suggestions would be appreciated.
I have been outboard motor restore hobbying for 4 years, now I feel like a rookie. This is my first seagull, so I'm screwing up already.
Thanks for any help.
David
Post by Stelios_Rjk »
Each laminate to be removed must be released from one screw and one stud. Not just undo the nuts, you have to remove the studs. Since the screws were defaced it was certain that you have to drill and retap. Threads are fine to avoid get loose from the vibration. I don't know if it worths getting another base plate or the whole system. Have a look here, this is a MK2 magneto and fits your engine. Not the original type as the one fitted to your engine but a later one.
http://www.ebay.co.uk/itm/SEAGULL-OUTBO ... 3382374064
You could use your cover even if it's not the appropriate. It doesn't really matters what cover you will use unless you care about originality etc.
skyetoyman
Post by skyetoyman »
The way to remove the Coil cheeks (laminates) is to undo the nuts , then use two nuts on one of the studs . Using two spanners - lock the two nuts together to form a lock nut.
Then use the spanner on the inner nut and remove the stud . They sometimes break but usually leave enough to use mole grips.
Under the cheeks is a small screw the holds the coil in the correct orientation. Plenty of experts on this site who are always willing to help . Please ask first
1650bullet
Post by 1650bullet »
Have you looked around for a coil and base plate toghether. I have removed a coil from the base plate and taking out the screws and they can be a mission. You can purchase the screws from villiers themselfs and there not expensive. Keep working on it. Have a break here and there and you will get them out in good time.
cajuncook1
Gentlemen, I was able to get a complete ignition plate and a good coil. Just have to wait near the mail box until it gets here.
Thanks for the explanations, links and encouragement!
Cheers,
David
skyetoyman
mark the base plate and crankcase before you remove it. Then endevour to line up the new base plate in the same relationship.
