Just bought an SD
Jan
Post by Jan »
Charles, After all the information we provided you regarding the JM and SD register I was wondering how many SD engines are on the list.
Any numbers per country, did you found new information/patterns with the numbers and will you publish the SD register in the future?
So far only 20 SD motors are registered, with a couple in the pipeline. The vast majority are in the UK.
Yes I will publish it - I have to say it's a boring document - but sooner rather than later.
JM 6854
Looking good under the paint, looks like it has never been apart.
Will post pictures later today.
SD 2862 L it was an L not a 1, what year does this make it?
Thanks for the numbers. I would guess that as about ten thousand were made between 1942 and 1946 yours would be 1943 ish.
Paint is coming off quite easily
It has the skeg stamp.
Prop and gearbox in good condition.
It has the remains of a side mount bracket.
Clutch lever is wrong.
Short Champion Plug cap.
The unplated air inlet trumpet has been cut down.
Throttle lever is correct
It has turned out to be a good buy for £41.00 in my opinion.
Tank is steel and has the remains of the gold sticker, cap is chrome and mint.
Will it be ready for the Thames Meeting?
Has anyone got a spare clutch lever? :)
Why didn't you ask me when you were here this morning?
Got it apart, very clean inside I would think it has run in the last few years.
The scuff mark on the piston skirt are caused by zinc that got into the bore when it was galvanised.
Tank stickers under paint, gold seagull facing right.
Petrol mixture works out at 6.4 to one :o
I think that the person who painted it white may have done me a favour,
under the paint it is well preserved.
This will be a quick rebuild, so it will go to the Thames.
timberman2004
Post by timberman2004 »
cross my palm with silver and I think I might have an original bronze 'donkey dick' clutch lever
will have a dig
niander
Post by niander »
pity about the air inlet
timberman what does the it look like...out of interest
your sd looks very much like mine
metric proportions that aint an original sticker!
i found this stamp on the prop...is this usual?
http://i169.photobucket.com/albums/u201 ... ICS020.jpg
In 1932 the first Marstons had the fuel mix in both Metric & Imperial ratios on the fuel tank transfers.
This practice continued until the early sailorman logo which only had Imperial mixes Charles P will have a better idea of the date.
If using Benzole they recommend oil mix 4.26 to 1 or if not 6.4 to 1. That is smokey!
Almost done, just need to do the gearbox and prop.
Neal have you found me a clutch lever yet?
I have kept as much of the original tank decal as I could. If anyone else gets a painted tank and they want to remove the new paint, the method that I used was to fill the tank with boiling water. This softens the new paint and you can scratch it off with your finger nail.
Gearbox wont take long, now just need a spark :)
There must be a way of dating SDs , mine has aluminium tank brackets and copper top, brass tank brackets and Ali top must be newer R.B.T. :D
niander
Post by niander »
You dont have a spark?
me neither...let us know whas wrong eh?
looking good !
timberman2004
Sh*t, H-A ..what happened to the day job, to have got this fettled so quickly ??
my SD Looks the same ...but <<snigger>> I've got a spark :lol:
still on the rummage for the clutch lever ...I've got a day job :shock:
I know it's in there somewhere ...bloody kids...will bring to the Ferrry Lane meet
timberman2004
PMSL.... :lol:
Hey ...H-A just noticed why you haven't got a spark
Um ...HT plug lead may help ? :wink: :roll:
