Hear you might have a suitable Thames venue for a bit of a gathering?
P.S. Break it to Charles L gently that he will never get on the plane
I was allways under the impression that a 20 inch transom required a longshaft. The boat isn't just a standard dory, it's a seahog probably weighs over 300kg and is only being used on windermere with a 10mph speed limit on the lake.rosbullterier wrote:Oh for goodness sake - poor old gc is taking all this machining from the thwarted marine engineers seriously while the truth is - you've got the wrong engine for the boat!!!
The Seagull Plus has a bloody great big propeller with a low ratio box to make it push heavy barges slowly.
The size of your 11 inch prop added to the size of the Plus gearbox added to the length of a longshaft tube means yes it will drag along the road off the back of your dory - because you need a nice standard shaft Century with the standard size four/five blade 9 inch prop.
There. - well there's been sod all to comment about for a while . . .
Got my two TC water pump housings back today with 3mm CAD machined from their bases ready to take the anti ventilation plates for the cat twin setup . . .
You are correct. With "performance" engines the rule for the depth/mounting height is shown here: www.smalloutboards.com/shaft.htmwas allways under the impression that a 20 inch transom required a longshaft
The bottom of the cavitation plate is 3" below the bottom of the boat. Where is the water pump housing in relation to the cavitation plate?Vic wrote:You are correct. With "performance" engines the rule for the depth/mounting height is shown here: www.smalloutboards.com/shaft.htmwas allways under the impression that a 20 inch transom required a longshaft
With your Seagull you need to ensure that the water-pump housing is always submerged or you will lose cooling.
If your transom top is 20" above the water level shortening your engine as suggested or fitting a standard shaft engine will not only raise the water pump above the water level but part of the prop as well.
If in fact you find that the top of your pump housing is more than 5" below the water then a standard shaft model will ft your boat.
FPL942KK5. I cut it down to FP specs. Standard 9", 4 blade prop. I weigh about 170 but my boat only weighs around 85 lbs, aluminum with a square front and flat 32"wide bottom. We call them jon boats. I'd post a pic if someone would explain to me how to do it! I'm not sure of the speed, maybe 7-8 mph.Charles uk wrote:Todd can we have your engine number?
Which prop do you have & how fast are you going & what do you weigh?
Your doing well to plane with a 40, Congratulations!
Open an account with Photobucket or similar. Upload your photos to there but keep the size down to "large " or 15" screen"I'd post a pic if someone would explain to me how to do it
