Charles SP - Through reading about Seagulls on this site, the spinning technique was used right after cleaning all of the contact points. Unfortunately there was no spark to be found. I just applied a multi-meter and set the probes at the HT contact point and the wire-weld area on top of the coil. I could not get any ohm readings so it looks like I may have a non working coil too. Looks like I will be looking for a few replacement parts to get this Seagull going. The good thing is there are still parts out there.
Villiers MK1 Condenser Inspection
sierramuir
Thank You Again
Thank you all for the condenser information
