sd 102 restoration. where do I start ?
Re: sd 102 restoration. where do I start ?
Cheers bro
- skyetoyman
back to work on the sd. Ran today but carb slide is sticking again and magneto base plate is loose. Frigging stick out again . May need a little heat to free the locking screw.
That carb body has always caused you grief, do you want to swap it?
- skyetoyman
No but thanks but. It's just the last 1/2 inch that's sticky. Won't need much doing and it doesn't leak.
