Read all the FAQs etc. and I am just going to put together an order for some parts, just want some advice on what I need to make it a single shop order rather than little bits and bobs.
Its a Featherweight, sold as running but leaking fuel.
We powered it up in a water butt.
1. It runs almost flat out! - no throttle control
2. No cooling water comes through
3. How can I stop the engine gracefully! (I had to put my hand over the intake). Is there any way to wire in a kill cord - I can only see a high tension circuit, not a low tension one.
Here is the engine...
I am going to buy the workshop manual, but in its absence I guess this is the remains of an air filter?
What bits should I buy to fix this?
One of the mounting clamps is broken, I guess I can weld a bit of metal across the end
The aim of the engine is to power my sons small boat project. It appears ideal for this except for the large piece of rotating hardware on top of the engine! Is there a cover available for this when running to stop him touching it? (I know this is a heresy for those restoring to original but this engine has been bought to do a job)
No sign of a fuel leak (yet!)
