The water flow from my TC 102 is sputtering with air, but it's set at the correct height in the water. If the waterways are blocked what is the best way of cleaning them without removing the block?
Thanks! red.
RD 102 head
Re: RD 102 head
Sorry, typed in RD 102 by mistake should be TC
Red.
Red.
Re: RD 102 head
It could even be a cracked cylinder wall.
In any case take the cylinder off the crank case and have a look. You can get to the water ways at the same time.
Re: TC 102 head
thanks, will do that . will let you know in a few days.
red.
red.
