Locking latch
Re: Locking latch
I have seen that chain in the shops before... now I just need to remember what shop!
Re: Locking latch
I have been discussing with John Williams of the possibility of re manufacturing & him stocking latch kits ( latch, 3 split pins & 175mm of brass chandelier chain).
Thank to Hugo's excellent work there seem to be 3 types of latch levers, small & large bird beaks & the wedgie. I've only been able to study examples of both of the bird beaks, which were stamped from 8 gauge brass sheet, not something we could do as the punch tooling for each would cost approaching £500 even at mates rates.
That would only leave laser cutting or water jetting providing that they already have suitable material in stock, 8 gauge or 4mm brass sheet, even then we could hit the "minimum order value" stumbling block.
We can't expect John to put 20 kit's on the shelf at a cost of £10 each, only to sell 2 in the first year, so an indication of how many are required this week, would decide whether this would be feasible!
Re: Locking latch
For us enterprising folk the hollow g'clamp's side faces are within cooee of the correct size. Angle grinder and a few minutes. I don't need any.... thanks. Be good if you can recollect location of chain shop Nudge
Re: Locking latch
I will keep me eyes open. It may have been in Bunnings awhile back I will look next time im thereBe good if you can recollect location of chain shop Nudge![]()
Re: Locking latch
I'm thinking picture framing shops. I'm sure it was used on old picture frames.Nudge wrote:I have seen that chain in the shops before... now I just need to remember what shop!
Re: Locking latch
You might be right there!I'm thinking picture framing shops. I'm sure it was used on old picture frames.
Re: Locking latch
Picclick. UK
£6 a meter free shipping
Or ebay seller (stop me and by two)
- Attachments
- 1m-NEW-Solid-Brass-19mm-Flat-Link-Polished.jpg (30.01 KiB) Viewed 10633 times
Re: Locking latch
Here's a picture of the 3 examples I have, the one in the chromed thrust block, taken from a fully chromed skeletal bracket is quite interesting, the chrome is not in the best condition & some has peeled off leaving good copper behind, we never found out exactly why some odd examples were chromed, our assumption was that these might be display models for a dealers shop or window display.
It has a different latch lever shape from the other examples that I've seen & is different to the wedgey, it is brass riveted in place prior to chroming & has a hole in the tip that seems to serve no useful purpose whatsoever, strange.
The other 2 are a small & a large bird's beak.
Re: Locking latch
I think you will find the latches on the skeletal are different again to the later std thrust blocks. Note the rivet and chain securing position.
Re: Locking latch
That accounts for the hole in the tip & no provision in the bracket side for a chain fixing point!
Thanks for a perfect answer!
Re: Locking latch
Well it seems there is no demand for any re-manufactured ones of these, so there's a job I don't have to do.
- fleetingcontact
Re: Locking latch
Are you saying you are going to get it and do the job? Thanks for offering!
- fleetingcontact
Re: Locking latch
If I had somewhere to install the beast I would definitely be interested. But I don't. Anyhow I expect the price may rise sharply above the 32 quid-sh current bid.
Re: Locking latch
Hi everyone
Took delivery of a LLS yesterday and noticed this locking latch made of plastic
Has anyone else come across one?
