Rusty Chrome Drive Tube
bobbynz
Post by bobbynz »
Hey Guys
The drive tube (???) on my 40 Plus Seagull is rusty azz ...
Are these easy to replace ??
Whats the best course of action ? .. remove and replace, remove and re-chrome or maybe mask it off, clean it up and spray it ??
Re: Rusty Chrome Drive Tube
That's not rusty! Ive got one that is ALL rust and it is still ok!
Yes very easy.
Take the gear box off the bottom and take the power head off the top.
I can talk you through it over the phone if needed (it is a lot easier than typing) Have a look at it then come back to us, it is good to keep things out in the open on the forum than doing things by PM but if needed I can help.
bobbynz
Post by bobbynz »
Awesome .... sounds easy
Mine does not appear to have a cinch bolt at the bottom end so it might just fall off ?? ... i read somewhere that the gearbox was braised onto the tube ? ... or is that the exhaust side ?
No factory braising off gearboxes to tubes. Yes your gear box could fall off. Some early ones had drive tube threaded onto box but not yours.
bobbynz
Post by bobbynz »
ummm interesting .. I shall investigate further ... and at the very least add a cinch bolt :-)
Post a pic, side elevation, of the water pump housing, lower unit & the bottom 50mm of the drive shaft tube.
bobbynz
Post by bobbynz »
here is the best pic I have here at the moment (ie Im not at home)
Notice no cinch bolt ?
bobbynz
Post by bobbynz »
Bolt missing! Clearer on my phone than puta!
The engine number will clear up the whole issue.
How far are you from Waiuku?
bobbynz
Post by bobbynz »
SJP31516
Im about 45mins from Waiuku ..
I suggest you talk to John C at Sandspit Waiuku or Nudge just over the bridge in Auckland, they both know what they're talking about.
Do I? ... Cool a complement I will take that :roll:
If you need something give me a shout, If I don't have it I can put you onto someone that has.
bobbynz
Post by bobbynz »
excellent thanks guys .... will see how I get on (when I get around to it) :-)
