Silver century plus
Dat999
Silver century plus
Post by Dat999 »
Hi Just a quick question. Is it possible to fit change the gearing ratio of a silver century plus from 4/1 to the 3\1 standard century. Basically I am looking to run the five blade hydro prob at higher gearing for a project this winter. Thanks in advance Dave.
geofflena
Re: Silver century plus
Post by geofflena »
Seems not to me - to run the large prop you would need the large crankcase - as it would not fit the silver century.
I doubt one could mount a 35 crown in the large box - as the pinion would not line up - but if you dropped the pinion bush It might be possible ? You would need a longer reach on the driveshaft as well - if it could be done.
The most cost effective way of doing this would be to buy the entire bottom end of a silver century, water feed pipe, drive shaft, drive shaft tube, exhaust, water pump housing & lower unit, & swap the whole lot, your in Kent why not try Seagull Restorer?
Not sure that the power head will generate the power to turn the larger prop at a higher speed?
I think you'll find it's exactly the same power head in every respect when you compare a century with a century plus that were manufactured at the same time.
Sorry Oyster I've just re read the question & it's not very clear, does he wants to run the 13" hydro fan on a 3.5:1 ratio box or the 9" 100 only hydro fan.
No ones racing in Kent are they?
