Sometimes you need to buy 3 to get 1
Re: Sometimes you need to buy 3 to get 1
Finally got to have a better look serial number definitely tampered with coming apart nicely.....all things green and brass.
Brass bayonet cap and plain clutch lever. Both rare ish parts!
So what are your plans with this Tam? Clean, service and reassemble or full resto?
As much as i like all things shiny i don't think I'll have it to long the more i remove parts from it the lighter it becomes china...
Sunday morning polishing a good hangover cure...
What no more green paint!
If you get stuck for parts to polish, let me know?
I'm a wejjie we don't do green think i might polish another 18yr oldKeith.P wrote:What no more green paint!
MALT XX
Looking at the engine number the second last letter/digit will be an L or P. Considering the placement of the punch marks it seems to be more likely to be a P which makes the motor a tad earlier than first thought but not by much.
Haven't we recently seen another motor with an engine # obliterated with a punch? Which motor was that? Odd technique.
Enjoy your malt.... a fine drop.
Looks good Tam. I've decided to give mine a clean and service for now. Goes against the grain for me, but want to see how it comes up with a limited resto. Can always be redone later or if I change my mind.tambikeboy wrote:Sunday morning polishing a good hangover cure...
By the way, what are your intentions re the barrel/cylinder? How is it going to be finished?
Thanks & regards
That is it finished spent Sunday morning tinkering with it even polished the good bit's hoping to find some motivation for the rebuild I'm afraid with a dodgy serial number and a missing original clamp i have no doubt that this will be the end of this motor hopefully get some others up and running along the way.......nice matching crankcase number's though shame about serial number....yes I'm Scottish and don't spend money.
Lol, I have so many on the go I'm feeling the same way, a little overwhelmed atm.
Reason I asked about your barrel is because mine still has approx 60% of the original plating visible. So I want to maintain that, but also want to prevent the rest rusting over. Therein lies the dilemma, how do I proceed? Oil, clear coat, or are there any other options worth considering?
Sd1863 arrived today looking forward to checking it out when home pics to follow...
SD1863
SKEG STAMPED
JM 9209
HIGH LOGO FLOAT BOWL AND TRUMPET
STEEL TANK
COPPER EXHAUST TUBE
BRASS THROTTLE LEVER (POSSIBLY BENT)
BRASS GEAR LEVER (PLAIN)
SMALL BROWN PLUG COVER (WILL COME IN HANDY FOR FVP
TRANSOM CLAMP BRONZE (BUT WRONG)
ALLY IGNITION COVER
LOOK FORWARD TO YOUR COMMENTS TO PUT RIGHT
CHINA'S
SKEG STAMPED
JM 9209
STEEL TANK
COPPER EXHAUST TUBE
ALLY IGNITION COVER
CHINA'S
Closer examination of fuel tank any suggestions china's
Wonder if that’s the remains of a MOD stencil?
