Spark plugs - Bosch
igor
Spark plugs - Bosch
Post by igor »
Hello Seagullers!!!!!!!
I would like to know if somebody use Bosch M10AC spark plug,or
Bosch M7A
Bosch M8A
Bosch M8AC
Bosch M8AO
Bosch M10A
Bosch M10ACO ?
My Seagull is WSPCL from 1979.
Many Thanks!
Happy New Year!
Igor
igor
Post by igor »
I have started my WCPCL in the barrel with Bosch M10 AC spark plug.
Fit nice into the engine and start good.
I hope that I will test it on the sea this summer.
Happy Seagulling!
Igor
mozart
Post by mozart »
Igor,
Baybe someone could supply a cross reference chart e.g
Champion-Bosch. This may help you to find the correct spark plug
as most know the Champion type.
I have tried Bosch M 5 A on a 102 but have only limited experience, works fine in the garden...
regards
Sten
igor
Post by igor »
Hello Mozart!
You have tried Bosch M 5 A on a 102 but You have only limited experience, works fine in the garden...
I have tried Bosch M 10 A C on my Silver Century Plus and I have only limited experience too, works fine in the garden…
I hope that someone of “United Seagullersâ€
mozart
Post by mozart »
Hello Igor,
On the net I found (in comprison with Champion D-16) the corresponding Autolite which is e.g. B9 and corresponding AC tis 86.
Could the international Segullers fill in this format which could a cross referencew chart for Spark Plugs suited.
kind regards Sten
John@sos
Spark plug types recommended by Seagull.
Post by John@sos »
The plugs today recommended and sold for Seagulls by British Seagull are the Champion D16 and the D21. (Think the D21 might be a hotter plug for use at low revs...) I have never used one and often use low revs with the D16 with no ill effect.
The equivilant NGK plug I often used to sell was the A6. Both these plugs are now classed as 'speciality' plugs with a price match!
Of course the old plug was the '8 COM' but these have been discontinued for many years, as has the even older Lodge plug???
I will look and try and find a full list and add it to the site.
SOS
CatiGull
Post by CatiGull »
You can get cross reference from one brand to another at
(WHere else??)
www.carsparkplugs.com
:D
I did try D16 and it didnt list a Bosch equivalent though....
However, it does confirm the NGK A6 as the 'equivalent' to the Champion D16, and Bosch site confirms CHampion A16 can be replaced by:
M7A
M8A
M8AC
M8ACO
M8AO
M10A
M10AC
M10ACO
M10AO
M45T1
M95T1
M95T5
M145T1
M145T5
M175T1
:cry:
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
