fuel tank tap cork
speedcase
fuel tank tap cork
Post by speedcase »
Hello Seagullies
I have to replace the cork on the fuel tap, it's leaking a bit when closed down, please any info where to buy is welcome.
I live in Holland.
Cheers Kees
chris
Post by chris »
Make your own.
I used a cork out of a wine bottle, drilled a hole through it and put the spindle that held the old cork into the hole, cut it to the right length and used the file on my leathermans tool to shape the cork, it is very easy, might take a couple of goes.
40TPI
Post by 40TPI »
For a new cork contact John, the host of this forum, at SOS. His number is at the top of the page or email him at john@saving-old-seagulls.co.uk. If you are unsure about how to change one check out the FAQ on the main SOS website:
http://www.saving-old-seagulls.co.uk/faq.htm
Then again there is a good possibility that you might not actually need a new cork. The old trick of taking out the brass plunger and boiling it in some water for five to ten minutes to rehydrate the cork is always worth a try before rushing off for a new cork. This technique is also written up on the main site FAQ link above.
Another approach is to use several rubber "O" rings as per :
http://www.idpp.org/idpp_eng/seagull_en ... #fuelvalve
Peter
speedcase
Post by speedcase »
Thanks, for the answers guys.
Kees
bruce nickerson
Post by bruce nickerson »
I have a plastic tap that leaks- any suggestions?
CatiGull
Post by CatiGull »
I replaced my plastic one with a nice brass one from John.
:D
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
