What ignition should this very early 102 have
Seagullrestorer
Post by Seagullrestorer »
Hello everyone, I'm usually pretty clued up on seagulls but this one has me stumped, what ignition should this seagull have, mk1 villiers with flangeless stator , coolie hat flywheel type or standard mk1 villiers .... I'm not sure how to add photos on here but it's ebay item number 321533299639 ( I bought it and now have it in my possession) look at that yummy bayonette style tank, I know it should have a bow tie prop ! Any help would be greatly appreciated
charlesp
Re: What ignition should this very early 102 have
Post by charlesp »
It's an early AD,so standard flat top Mk1 ignition, plain aluminium cover. And swept back 2 blade prop, as per SD etc. The "bow tie" was a mofification of the swept back version that allowed for the use of the "sub-ejector" exhaust.
Seagullrestorer
Thanks for the quick reply, I'm glad the ignition on it is correct, I have a marston with a straight exhaust too awaiting restoration
THCL500J8
Post by THCL500J8 »
This is the engine he means AD3816
Seagullrestorer
Thanks for adding the photo, it's about 10 years since I last used these forums do I'm a bit rusty on how to add photos etc
hi SEAGULLRESTORER
i've PM'd you :D
that looks like a good project, mostly all correct for an early post war engine, as Charles says, the prop should be 2 blades swept back, SD style prop. Can't beat an early 102 :
It even has the original fuel pipe by the look of it.
Seagullrestorer
It is an easy resto by the looks of it. I decided I wanted it in literally minutes after it was listed on ebay, apart from the drive tube which I have a replacement for and like you say the prop it's all there and it's coming apart really easily and no corrosion on the aluminium which is the main thing, original fuel pipe is a nice little bonus, not bad for £45 plus £15 postage,
Niander101
Post by Niander101 »
Yummy throttle as well.... may of started life as an sd as it has the sd exhaust flat outlet
""I decided I wanted it in literally minutes after it was listed on ebay"
I know how that feels. :oops:
Good refirbisher by the looks..............................enjoy and keep us posted aye.
Seagullrestorer
It's coming apart very nicely, I have quite a few of those throttle levers, anybody who knows me will tell you I have a huge stock of spares but anything rare I keep because I'm
greedy like that :-)
Some what Noted.
Enjoy and send pics.
We all like Pics.
