Conversion Kit -
- remote throttle lever and mounting bracket (a mirror image of your exisitng gear lever for the port side)
- correct throttle cable
- brass cable retaining post with nut
- linkage frame for gear along with the correct machine screws for securing it (screws directly into your tray)
Original Control Box and Cabling -
- ultraflex remote cotrol box with single lever that engages forward or reverse at the same time as powering up. This makes it impossible to over rev the engine in neutral and ensures that drive is only ever engaged at idle tick over.
- throttle and gear cables are already fitted to the control box
- tiller cable also supplied
All you need is a 170 Seagull, a boat to hang it off and a ships wheel and you have your very own Seagull driven Gin Palace!
I'm happy to split the conversion kit and Control Box.
Open to offers or come around and have a look if your around or passing through Stirling!
Reply to the thread or email contact(at)sgreig.co.uk [Replace "(at)" with "@"]
