Jinx is quite a nice runabout, if you google using the phrase I put in inverted commas you will find loads of free plans, all of which were meant for first time boat builders.
Pick any of the simple ones you fancy & go for it.
My next boat
Re: My next boat
Re: My next boat
Have found another nice one.
This is the one I will try and copy.
But I will reduce the length, and beam to make it more suitable for a Seagull.
Also I found some pictures of the bottom shape.
Roll on the spring and better boat building weather.
Re: My next boat
H-A, here's yet another view:
Re: My next boat
Thanks Todd
Nice original boat, nice Merc.
Was that taken at Lake Shipp Fl. AOMCI meet?
Re: My next boat
You could very well be correct, as it is one of the random photos that appear on the AOMCI home page.
Re: My next boat
I'd be very suprised if a 102 cc Seagull could not push one of the very pretty hulls at quite a bit better than hull speed.
HA has proved before that he can build lightweight hulls, these are 12" ish almost flat bottomed boats built strong enough for a 30 hp+ motor, with modern construction methods & for a much lighter motor, he will be constructing one he can easily carry on his own.
I'll wager that he will be able to double it's hull speed!
Re: My next boat
I will build it slightly shorter and a bit less wide.
I would hope to get it built at about 20kg.
With an on-song century I have very little doubt that it would not be getting near three times its hull speed.( hull speed being about 5mph)
Perhaps if there is going to be a visit to the Crouch next year, I may be able to let it rip in the unrestricted bit.
Does John need a little prod to set a date in the diary for next year, as this years run was such a success.
It would be nice to have a calendar of events.
