60/61 40plus
Mutineer
60/61 40plus
Post by Mutineer »
Another 40plus question
I have a 60/61 SJP that runs really quite well (quite smoothly compared to the 72 mentioned previously)...except when it gets really going it seems to "buck"/rock fore and aft on the mount, more of a physical movement than a engine one (this is in a barrel)
The prop is off and the mount seems secure and I haven't experienced this movement on any of the other 40 pluses I have/had
Any ideas?
Thanks
Go for the juggler!
RickUK
Re: 60/61 40plus
Post by RickUK »
As you have the prop off, I assume you are just experiencing a lot of turbulence induced by the exhaust into the water. may change depending on the diameter of your barrel or the water level - nothing to worry about. I guess you have a plastic barrel and the mounting area is flexing?
Perhaps it's a powerful brute!!
