Condenser for British Anzani Pilot Wipac series 161 Magneto
jimxx22
Post by jimxx22 »
Please could someone tell me the correct condenser to use on a British Anzani Pilot, which has a Wipac series 161 Magneto.
The correct capacitance value, or an obsolete or modern OEM part number., would be great.
hansomcommon
Re: Condenser for British Anzani Pilot Wipac series 161 Magn
Post by hansomcommon »
Hi Jim, the value of the condenser is 0.1uf 400vdc but the need for a rugged physical case is most important! Any of the modern moped type capacitors will be fine if they are the similar size & are alumimium cased., Rog.
