just to be on the safe side
could i do any damage to a seagull engine by running a radiator flush through it to clean the cooling system? i have read a bit but have never seen this recommended so just wondering. cheers
- timberman2004
Re: just to be on the safe side
but it won't do much good either.....
you'll find that there's probably a load of clag (technical term ) built up inside the water jacket
if you're game enough remove the cylinder and strip completely then attack the galleries with a stiff wire
high pressure jet can help, and I've had success in heating and cooling the cylinder and getting at it with the wire
hope that helps
hope that helps
ok thanks guys.i just thought an occassional flush might help prevent the "clag" forming if it was reasonably good in the first place
You do not say exactly what you mean by "radiator flush"
A domestic heating radiator flushing compound? Should not do any harm but may not do much good.
A car radiator flushing compound? Like wise is not going to do any harm but may not do any good either.
To clean up a system that is already a bit clagged up there are several things you could try
RYDLYME which appears to be a hydrochloric acid based cleaner and should be quite effective in removing limescale bound deposits.
A sulphamic acid based central heating boiler de-scaler such as Fernox DS3. Likewise effective in removing limescale and available from plumbers merchants and DIY stores
Holts 2 Step Radflush SEE HERE
As a very drastic measure a hydrochloric acid based brick and masonry cleaner
Do not try to take the head off!
unless you absolutly have to
ive never had to yet...
NO!
Dilute it in running Drum first.
