Page 5 of 7
Re: Australian Riptide Sportsman
Posted: Mon Apr 27, 2015 8:06 am
by AusAnzani
Thanks B, that's exactly what I expected hence the question re the outlet on the bottom of the cylinder head. It seemed superfluous (unnecessary) to me ie as I hadn't considered drain or flush as potential features.
Sorry Charles, I missed your previous comment. I think you're absolutely spit on in suggesting there is probably a drop in replacement impeller out there. The problem I had in finding one however is that not many impeller suppliers list the critical dimensions. It was therefore easier to go with the Evinrude impeller and increase the bore to suit.
I do take your point though and agree 100%.
Posted: Sun May 03, 2015 8:43 am
by AusAnzani
Posted: Sun May 03, 2015 10:21 am
Interesting sinc plate under magneto.
Would like some pics as to how linkages etc move and groove aye.
S!
Well Done Mate!
Posted: Sun May 03, 2015 11:23 am
by AusAnzani
Mate, i found the shape of that synch plate odd during disassembly phase. Throttle linkage rides over the top of synch plate, nothing following its edge, so the shape is somewhat confusing.
This sportsman doesn't seem to have a mechanical advance. Does yours?
Posted: Mon May 04, 2015 4:01 am
by AusAnzani
AusAnzani wrote:Mate, i found the shape of that synch plate odd during disassembly phase. Throttle linkage rides over the top of synch plate, nothing following its edge, so the shape is somewhat confusing.
G'day B, please park the above for now. My Sportsman does have a mechanical advance, can't believe I forgot about the linkage to the ignition plate.
Suspect my synch plate may have been bent out of shape, hence my above comment above re nothing following its edge.
Will need to figure how it all works during reassembly. To my way of thinking, shape is still very odd.
Posted: Tue May 05, 2015 8:59 am
A very strange shape indeed.
When the go fast lever on yours is turned up loud..........does it turn the ignition base first. Then does the plate attached, in turn, open the carb via any form of a follower edge on ...........like it being carb/ignition sinc that we all know?
It is a very strange shape for any advance/throttle position to be...........linear.
I can never tell with your pics ...............does yours have this well defined advance track/limiter for the base plate?
B[/color]
Posted: Tue May 05, 2015 10:01 am
by AusAnzani
Hi mate, no, definitely no advance limiter groove in mine. Just double checked to be sure, to be sure as the Irish say.
Go fast lever definitely moves the ignition plate, but the small u-shaped linkage that operates the slider on the card doesn't make contact with edge of sinc plate until near the end. At that point, the said linkage runs over the top of the sinc plate, thus lifting the slider (opening the throttle). Clearly not right!
Is your sinc plate flat or does it have a downward bend in it?
Unfortunately I didn't take any pics during the tear down, hence it's more difficult for you to spot all the differences at the moment. Once it's all back together, things will be much clearer.
Any questions, please feel free to call aye. Sometimes its easier! We will share on here regardless ie for current and future readers.
I thought my pics were pretty good, now a little deflated
Posted: Tue May 05, 2015 10:30 am
No "De Gassing" intended I assure you S.
Your outstanding attention to detail should justifiably keep you pumped.
Just that I would like to see what I want to see..........how would you know. Sorry.
A call this weekend is warranted as I believe this may be the first important difference between our motors.
I will text first so that we have things in front of us at the same time aye.
Posted: Tue May 05, 2015 10:39 am
by AusAnzani
Just reassembled the bits and have taken some new pics for you.
Will post em up shortly and all will be revealed, including corrections to some statements I made earlier.
Turns out my synch plate performs more than just advance and throttle functions.
Hang 10 whilst I upload new pics to photobucket.
Posted: Tue May 05, 2015 11:33 am
by AusAnzani
Sorry for the delay. Wife wouldn't let me post until I finished my dinner
Let me begin with an apology to you B for leading you up the garden path. When I first got this Sportsman home, it had been tampered with, lots of nuts and bolts missing, others very loose etc etc.
As it happens, the 2 countersunk screws (you have hex head bolts) securing the synch plate to the ignition plate were very loose, almost to the point of falling out. The result of that was that the small U-shaped throttle linkage (under spring tension from the carb slider) rode over the synch plate rather than along it's edge. Hence my previous misleading comments. I'm real sorry about that mate!
Now reassembled correctly (well sort of) it all becomes very clear. The odd shape of my synch plate actually provides three functions.
1. Mechanical advance
2. Throttle
3. Min and max end limits for the mechanical advance (achieved on you Sportsman via a groove in the collar ie as pictured in your above post).
So here's the detail. Apologies for the poor lighting.
Off position. Mechanical advance at minimum end limit.
Start position. Mechanical advance engaged. Throttle still at min position.
Full power position. Mechanical advance at max end limit. Throttle wide open. In other words, my favorite position
Mystery of the "odd shape" synch plate solved!
PS: Synch plate is definitely a little over-bent eg as it is I do not actually have wide open throttle.
Posted: Tue May 05, 2015 12:45 pm
That answers my questions aye.
Mine is way different...................Same thing regarding call this weekend S
Now we are into it!
Posted: Tue May 05, 2015 2:55 pm
by AusAnzani
Cool
Posted: Fri May 15, 2015 6:46 am
by AusAnzani
Just a quick update to let you know what's been going on.
I received a response to my email to Barry Sheltrum, son of Leonard (Len) Sheltrum who founded the Riptide Outboard Motor Company. To say I was excited about that would be an understatement. In due course, I will post a summary of the information Barry provided which includes an image of Len holding an
Australian Power Boat Association - Certificate of Speed Record dated 31st March 1959, Wagga Motor Boat Club, Lake Albert. Boat - Riptide II (No. 404) A Class Racing Runabout, Powered by a 242cc Riptide Sportsman Outboard. The speed noted on the certificate is 28.637mph.
This is interesting for a couple of reasons. Firstly, it is the first piece of evidence that confirms Riptide Outboards had been raced and secondly because the certificate states 242cc whereas the standard Sportsman was 200cc.
An image of Riptide II can be seen here:
http://gallery.myff.org/gallery/1677656 ... ice+59.jpg driven by Frank Rice also 1959
As for my Sportsman, the upper and lower cowls, gearbox and trunk (mid-section) have been attended to and are now free of those casting defects shown in previous pics. I hope to achieve same with the swivel and transom brackets this weekend, and should the weather gods allow, I might even attempt application of the base coat.
Barry confirmed the original colors for the Sportsman were White or White with Yellow upper cowl ie as was noted on my very own during the paint removal phase.
That suggests the color schemes were changed (or added to) by Westcott Hazel following acquisition of the Riptide Outboard Motor Company. The acquisition will have come with stock of completed outboards and pre-painted parts, which were simply painted over with the WH color schemes, which included the gold/bronze on my Sportsman.
Image of another Gold/Bronze Sportsman donated by Barry to the Powerhouse Museum Sydney in 1983 can be seen here. Note the yellow and off white paint showing under the gold/bronze.
http://www.powerhousemuseum.com/collect ... irn=213341
No pics from me this time.
Posted: Mon May 18, 2015 8:45 am
by AusAnzani
G'day all, just another quick update.
Spent the weekend refinishing all components in Wimbledon White (creamy color) which should be a very close match if not exactly the same as the original.
Sorry about the image quality. I probably should start using my camera again instead of the phone! Just being lazy
Reassembly will commence soon after the paint has fully hardened.
Posted: Mon May 18, 2015 10:11 am
by notav8
Looking Good Mate , as usual.
