Page 3 of 5
Re: Non seagull outboard I. D
Posted: Wed Jan 16, 2019 8:20 pm
There is a chance that it is asbestos in which case l would suggest you give it a light scrub in a mixture of water and vinegar (no dust) with a toothbrush. Clean the inside windings with a fine grade emery cloth so there is good connectivity as well as the slider. Use a bit of masking tape on the inside, slider contact and connection terminals and varnish the rest (rattle can varnish).
If you can find an old arc welder you can steal the cable for controller to motor and you can cut off the ends of jumper leads for the two cables to the battery. Good fun. Any chance of a vid of it running?
Posted: Thu Jan 17, 2019 9:23 am
by tambikeboy
Excellent idea there Hugo except for the steal bittie (I'M SCOTTISH) I've given it a total strip down shouldn't be too long with this wee fella VIDEO to follow.
Posted: Thu Jan 17, 2019 9:51 am
Ha! A cultural difference in terminology. If we want something we ask if we can "steal a bit of that" You would be a bit pissed if somebody hacked off a foot of welder cable. . Like someone cutting a bit of hose for their bong..... why do they always cut off a bit in the middle?
Posted: Fri Jan 18, 2019 9:27 am
by tambikeboy
Stripped down ready for rebuild new 6mm cable should arrive tomorrow hopefully get wrapped up this weekend..
ceramic washers look to be past there best will get away with making a few rubber one's
Posted: Fri Jan 18, 2019 9:38 am
by Nudge
Only if they don't get hot?
Posted: Fri Jan 18, 2019 9:51 am
by tambikeboy
Nudge wrote:ceramic washers look to be past there best will get away with making a few rubber one's
OH what a good thought that is. Back to the drawing board.
Posted: Fri Jan 18, 2019 8:54 pm
by Nudge
Try a fiber washer, it might be able to take the heat better (maybe)
Have a look on ebay
https://www.ebay.com/p/10-Sets-5mm-ID-H ... 2211008108
Posted: Fri Jan 18, 2019 9:00 pm
by tambikeboy
Nice one I'm on the case
Posted: Sun Jan 20, 2019 12:09 am
by tambikeboy
A simple flexible drive. Missing tiller get this shapped it should compliment it nicely.not truely understanding this speed controler just yet I done a simple light bulb test on it.a 9v battery and and bulb no matter where I touched it lite up.....
Posted: Sun Jan 20, 2019 12:39 am
That is coming up well. Controller works on ohms law. Electrical current is proportional to voltage and inversely proportional to resistance. So not enough current passing through globe to make a difference to voltage. Am l correct Spiro?
Posted: Sun Jan 20, 2019 8:32 am
by tambikeboy
Hugz wrote:That is coming up well. Controller works on ohms law. Electrical current is proportional to voltage and inversely proportional to resistance. So not enough current passing through globe to make a difference to voltage. Am l correct Spiro?
Just spent more time on Google trying to come to terms with those big words china you crack me up..
Posted: Sun Jan 20, 2019 9:35 am
Negative temperature coefficient will also impact on the resistance of the controller, fortunately being DC, impedance won't negate conductivity of supply.
Posted: Sun Jan 20, 2019 1:20 pm
by tambikeboy
Still waiting for new cable's to arrive new bush fitted to bottom drive shaft (where's my other candle stick THOMAS) made a the missing tiller I think it compliments it nicely..
Posted: Sun Jan 20, 2019 7:20 pm
by tambikeboy
I'm assuming that these to screws are for inserting grease very ingenious (yes I looked that word up chinas) also got an approximate date of 1938....hurry up cable's.
Posted: Thu Jan 24, 2019 9:44 pm
by tambikeboy
A bit messy inside went this far might as well give it a tidy up.
