Page 2 of 3
Re: Metal Polishing
Posted: Mon Mar 06, 2017 10:29 pm
Just right I would say. I remember that engine
Re: Metal Polishing
Posted: Mon Mar 06, 2017 10:48 pm
Surprisingly I do prefer the "oily rag" look rather than the blinged up ones but nevertheless I am drawn to the idea of polished metal. Could come from that I grew up with an old man that was an officer in the UK RN and his idea of relaxation was to polish every bit of metal in the house including copper pipes in cupboards
. I'm assuming on a frigate etc every pipe etc in the engine room was polished to a high degree from the expression "The Devil/Master makes work for idle Hands". Sounds religious which maybe why the Yanks often go for the bling look.
I think I'll keep an eye out for a single phase 70/80's polishing machine which will match my other workshop machines. My drill press can be pulleyed up to 2000 revs though I wouldn't want to put sideways wear on the lower bush for obvious reasons. Good idea Rick to pick up a spares part spindle/taper. Fortunately I turned my dining room into a workshop (joys of being single) and have a 2.7 metre long and 1 metre wide workbench made from railway sleeper which I can work on from three sides which gives me 6.4 metres of work space. The carpet and curtains are a bit of a fire hazard though
Off to Bunnings for a snag sanger and some emery cloth and wet n dry. I hear Bunnings are now in the UK.... what do you think of them?
https://www.pedestrian.tv/news/arts-and ... 179d0a.htm
Yep, the coppertops lend themselves to spit and polish me thinks...
Re: Metal Polishing
Posted: Mon Mar 06, 2017 11:53 pm
Find yourself a 1.5 hp motor with the shaft protruding 100mm from each end, you should be able to find the right size tail ends on Ebay , then build yourself a heavy pedestal stand.
Re: Metal Polishing
Posted: Tue Mar 07, 2017 4:24 am
by AusAnzani
Hugz,
I used the very same kit following the sanding techniques described by Rick to 'bling' my Anzani Pilot.
Lot's of hard work and don't know that I'd want to repeat unless I'm restoring another outboard with badly scratched or damaged castings.
Re: Metal Polishing
Posted: Tue Mar 07, 2017 4:54 am
Oh wow. I would be happy with that finish Spiro.
Re: Metal Polishing
Posted: Tue Mar 07, 2017 1:14 pm
That's a very well finished engine. Nice
I tend to go down the route of mechanically correct and tidy looking, rather than bling. I like originality too. My motor bike I have just finished has gone down the route.
Re: Metal Polishing
Posted: Tue Mar 07, 2017 1:29 pm
by tambikeboy
Now let's see the bike china..
Re: Metal Polishing
Posted: Tue Mar 07, 2017 7:51 pm
Not that i'm knocking the "bling look" but it seems there are quite a few of us from here that like an authentic (but not overly done) seagull or any outboard for that matter. What determines an original finish can be a sensitive subject to some, as long as its tastefully done.
As Oyster's mentioned, mechanically correct (as far as possible) polished to an acceptable level that one doesn't need sunglasses
and definitely NO SILVER SPRAY PAINT
(how many times have we seen this before YUK) unless of course it was an original finish applied by the manufacturer. As Keith said, if it was painted before then repaint, if it was polished before then repolish.
Restoration or refurbishment, call it what you like, it's basically trying to bring back something old to as close to what some would call "as near as new".
I think that would do for most of us really.
BTW Keith, i remember that particular SD that you outbid me on.
It turned out alright in the end didn't it. Just about right i'd say.
Re: Metal Polishing
Posted: Tue Mar 07, 2017 8:29 pm
Was that the one.
I only have two, at the moment.
I totally agree Jon, as close to original if possible, once you use them, it doesn't take very long for a motor to look like any other used motor in the shed.
If you want to polish it all up, so be it, it wouldn't stay like that too long, if it was used, but standing next to the telly, why not, not for me though, I don't own a telly.
Re: Metal Polishing
Posted: Wed Mar 08, 2017 1:40 am
by AusAnzani
Believe it or not, I prefer the original factory look also. Problem for me is most of the vintage outboards I find have extensive salt water and/or have been badly mistreated. So to make good, I often find that I have to do things that may surpass the original finish
That said, I have seen plenty of original adverts for vintage outboards (Seagulls, Riptides etc) and albeit that these adverts are generally black and white, they exhibit a high level of reflection / flash from many parts which implies at least a semi-bling finish.
The Pilot in my above post was to be my first and only vintage outboard .... before I caught the bug. Plan was to store in my study and wifey would only allow that if it was made to look real nice and didn't smell.
Re: Metal Polishing
Posted: Sat Mar 11, 2017 3:31 pm
That's half the trouble with knowing exactly when to stop and say enough is enough.
Any outboard motor, doesn't matter what it is, will only be truly "original" once in it's lifetime.Usually when it's considerably newer.
After a few decades of use and perhaps several different owners, things take a very different turn. Damage,repairs and neglect all get in the way.
As you say Spiro, saltwater corrosion can be a sod to get rid of properly, and often the only real way is to polish far above the designed finish, hence some of the "blingy" parts we see today.
I bet that if you purposely forgot to re-polish your hard work it would dull down quite nicely to a more (choose my words carefully here) seasoned look.
Think yourself lucky Spiro. A study and somewhere warm and dry to show off your handy work. I'm jealous...
I have to put up with a cramped 10x8 shed and if i'm lucky (when she's not looking) sneak a few up into the attic for safe keeping, hidden underneath an old bed sheet.
Re: Metal Polishing
Posted: Tue Mar 14, 2017 5:58 am
by AusAnzani
You're right John, I shouldn't complain.
Just need to get my act together and have a good clean out. Both garage and shed are full of junk that's unlikely to ever be needed or used again. A clean out will give me room to move and maybe a few more outboards.
PS: I suspect a lot of that high bling stuff we see in the US is plated, not polished in the traditional sense.
Re: Metal Polishing
Posted: Wed Dec 06, 2017 10:12 am
Yes! Have a polisher now. Won it over a game of pool. Might go back and play for a lathe. Was a tad more exciting in the seventies...
Re: Metal Polishing
Posted: Fri Dec 08, 2017 4:30 am
by AusAnzani
I am pretty handy with a pool stick and need a few more tools. Might be up your way soon aye!
Re: Metal Polishing
Posted: Fri Dec 08, 2017 6:59 am
Doubles it is then. Finding a mark with the right tools is the hard bit
