OA Parts
OA Parts
This a last try for me and OA262 before getting into some serious internal modifications that can never be reversed once done.
This means that 262 will never be "proper" within... ever.
I have a standard piston for a 50mm bore and a cylinder that is 0.020" oversize.
I would like either a standard cylinder OR an oversize piston.
OR
Some other way of sorting out with hard parts either way.
If anyone can help PM me please.
Funds exchanged as per usual.
OR
Re: OA Parts
Charles is your best option Bruce, he will have all the information of what is available on the Marston Register spares list. There should be lots of spare pistons as cylinders fail most.
Not sure what the standard bore size was, replacement cylinders are very rare and expensive. I would think making a new piston would be the best option, and match it to your cylinder bore.
Get it going and I will race you for pink slips.
https://www.youtube.com/watch?v=jPA8ySSR40Y&t=3s
P.S. Hope that was not too childish for you Keith P !
Re: OA Parts
Can you post a picture of the crown of your Marston piston & the diameter of the wrist pin, as I've never heard mention of over size pistons & cylinders.
I've worked on more than 25 Marstons of all flavours & provided tech support for many of owners on the register & just wonder if someones tried fitting a piston from something else when reassembling .
Re: OA Parts
Yes I can Charles.
Piston is 49.70mm diameter
Pin is well worn 9.49mm to 9.47mm
I feel more than happy now the old dear may get sorted in this regard.
Re: OA Parts
I like that (pink slips ) but my aim is not to go fast but just 6 hours in one day down and back the Donnelly River.Horsley-Anarak wrote: ↑Wed Aug 19, 2020 5:28 pm Get it going and I will race you for pink slips.
H-A!
That is both ways and still running at the end of the day. The return trip will be somewhat lighter depending on beers consumed per hour aye.
Then retired finally on display in the lounge room.
Not many of these have the chance of being worn out in one hemisphere and brought back to some operation in the other.
Kind of
Re: OA Parts
Well that's a standard early OA Piston.
I've lent my bore micrometer to a mate, I'll get it back & measure the bore.
Re: OA Parts
Thank you Charles
My bore is 50.66mm by the way.
Remember back so many years ago we had a chat about there being a crankcase gasket between halves?
This is the reason for that.
Diameter to big.
Thank you for the help in this.
Diameter to big.
Re: OA Parts
I’ll have a look, I’ve got a couple of spare pistons, slightly different from each other, I’ll measure them up. I’ve also got several cracked barrels which I’ll measure out of interest as I’ve never really taken any notice, when I strip an OA I tent to clean up the bore and piston, pop the rings in the bore, if worn I replace the rings, get the ring gap correct then reassemble. It’s never occurred to me to measure everything up if all looks well.
I’ll get back to you with the piston measurements.
Re: OA Parts
Here are some sizes it pretty much any piston will fit any barrel
Re: OA Parts
Thanks for this.
Pics and details not often seen like this which is extremely helpful for everybody.
My barrel 50.65mm is obviously the problem.
Hepolite 14465!
Nice to know that my friend.
Very
Hepolite 14465!
Very
Re: OA Parts
Maybe re-sleeve the cylinder?
Re: OA Parts
It might be cheaper & less scary to have a custom piston made.
Re: OA Parts
Charles, you’re probably right there, a piston would be cheaper and much safer.
Re: OA Parts
By the sounds of this I have missed the boat in regards obtaining a barrel ?
Yeh I left the old dear too many years I am convinced.
Getting a piston made as a once off is not cheap in Australia. I estimate about $700.00 for one.
Then the barrel base does not fit into the cases properly....
NUTS!
NUTS!
