102 help
lecras806
102 help
Post by lecras806 »
Hi everyone, I have just started my first 102 restoration. I have done 40's etc but not a 102. I have the power head, fuel tank and exhaust tube. What carb and gearbox/prop went on these? WHCL459R6
Thanks Will
Re: 102 help
The 102 used the Amal 2 jet carb exclusively. However, the replacement if it failed, in later years, was the 416, so some may have been changed. Strangely enough that carb will run reasonably happily on 10:1, which older, pre 1968, motors should run on. :twisted:
Re: 102 help
Search on here for barge pusher gearbox & prop, 13" four bladed cloverleaf & 4:1 gearbox.
lecras806
Re: 102 help
Post by lecras806 »
thanks for your quick reply's. will hunt trough the web for the parts i need.
red42hj
Re: 102 help
Post by red42hj »
Hi, just looking back at 102 help. regarding the prop and gear box; 4:1, does that mean 4 turns of the flywheel to 1 of the prop?
cheers, red.
thcl500j6
Re: 102 help
Post by thcl500j6 »
Yes
thcl500j6
Re: 102 help
Post by thcl500j6 »
This is a short shaft barge pusher engine. i have three.
Hope the picture helps.
roxylass
Re: 102 help
Post by roxylass »
Beautiful machine I have the long shaft version
Just ordered a new high tension lead for it
red42hj
Re: 102 help
Post by red42hj »
Hi, Just checked my TC102 gear ratio, and it is 5 flywheel turns to 2 prop turns. Do I have the wrong gearbox?
thcl500j6
Re: 102 help
Post by thcl500j6 »
Post a picture of the gearbox, and we will put you on the right track.
red42hj
Re: 102 help
Post by red42hj »
Thanks, attached are 2 pics. the engine is TC 55048L 1956 to 66. long shaft clutched
regards. Red.
Re: 102 help
If you check your serial number in the identifier it should tell you all.
TC **** L which is a 102 with a clutch & a 2.5:1 gear box, long shaft & pre 1963.
It would need an H to have a 4:1 lower unit from new.
red42hj
Re: 102 help
Post by red42hj »
Thanks Charles, it seems the g.box is right for the engine. what would a 4:1 box be used for though?
The reason I queried my box is that the engine gets a bit warmer than it should when made to work hard and then breaks down . I've had to use a smaller prop than normal to get the speed up and get good cooling. But of course the boat speed is down then.
thcl500j6
Re: 102 help
Post by thcl500j6 »
This when its full of crap and people. Or towing other boats back home.
Re: 102 help
That would imply your cooling system needs checking from A to Z.
