All in usable condition, I've measured the main bearings and they are within tolerance.
There is a cylinder head but it seems this engine was dropped at some point because there's a chunk broken off, which I have. Maybe it can be repaired.
Sale or swap.
FVP cases, crank, con-rod, piston
- fleetingcontact
Re: FVP cases, crank, con-rod, piston
HI, I am interested in the cylinder head,
I will send you a pm.
I am also interested in the con rod. Please send me a pm.
i would like to make a record of the serial numbers on the crank cases, so would be grateful if you could make a note those down here.
Thanks.
Thanks.
- fleetingcontact
Two emails sent!
