Locking latch
Post your wanted adds here
Locking latch
:oops:
Re: Locking latch
I’m after one of those too :shock:
Re: Locking latch
I'll keep eye's pelled this end x2 ru not getting ur pms china
Re: Locking latch
I'm could do with a couple, has anyone got an unmessed with example, that we could do a drawing of, I can't think of a reason why we couldn't have several laser cut.
The hardest bit would be finding 1/8" bronze sheet that's the same colour!
Failing that machine up a pattern with the same profile so that a bronze bar could be cast, that was then cut into 1/8" slices.
Has anyone checked to see if British Seagull or John has any in stock?
Re: Locking latch
I've just had a chat with John Williams, they are no longer a "stock item", He's going to have a look to see if he's got a real good example so I can do a 3D drawing & then a feasibility study on re-manufacturing some for him.
So you'll have to wait you impetuous Scotsman!
Re: Locking latch
What does that mean or will I have to Google it...
I'm only a wee thick gezzer from the heart of scotland
Remember I do have your postcode
And a hacksaw :evil:
Re: Locking latch
That's how you got out of the Bar L!
Re: Locking latch
I thought they came with that latch at least some of them. Some have a hole for split pin and others, the split pin goes in front for open and back for locked. Two left ones are damaged.
Re: Locking latch
More:
Same story with skeletal:
Another skeletal, no holes for split pin but either side.
Re: Locking latch
I'm putting forward the synopsis that earlier ones were wedged (wedge latch) shape with one hole and later ones were the sexy sickle shape with two holes (sickle latch).
Another:
Re: Locking latch
Digressing....
Is this a century with a metal thrust block? Looks a bit like it but no chain to pin. Maybe he put the chain in the wrong place. Skeletal had chain to the sheppard's crook bar but not that I know of on the std brackets. Remember these are artists impressions.
Re: Locking latch
Small birds beak?
Is this the one your after? (if it is not I will need a good pic so I can draw it up) If it is give me a week or two and I will cast some.
How meany do we need?
Re: Locking latch
Many thanks for your kind offer nudge it was the full locking device that I was after I now have one cheers ... 8)
Re: Locking latch
I now have one of the Nudge styled ones, thanks John.
They appear to be stamped from 8 gauge brass sheet, I will see if I can get a 3D drawing done Nudge.
If I can find a laser cutter who stocks & will cut the right gauge material it will save time & money.
What I will need to know is what sort of chain was used to retain the locking pin, & the only one I've got with chain looks like their bath plug is no longer retained, & the chrome is starting to chip.
It would probably be easier if John stocked & sold the whole kit, latch, chain & the 2 sizes of split pins, it would save the owner a lot of driving around town looking for 2 different pins.
Re: Locking latch
Chain and pin. Of course the little pin that fastens chain to bracket broke. Left click twice.
