Coolie hat flywheel
Re: Coolie hat flywheel
"ps I really am working on getting the data published quite soon. Honest .It takes a bit of time that's all."
You just put yourself on a forgotten back foot Jon.
tambikerboy wrote:Try ebay as of 24/10/2016 rustirelics
IT'S BACK.....
That motor is an SD.XXXX.L4
SD85xx apparently. Looking at it seems to been chopped to a shorter shaft length, and an early plus gearbox with lube nipples fitted. Not a lot to see here methinks. A parts engine.
That's what I thought, best not give the number away SD.XX06.L4
30 bob and a can of lager
Thats about what its worth. Knackered old thing.
