102 longshaft drive tube with good chrome wanted
I'm after the thicker chrome leg off a 102 or similar. Longshaft and with clutch. Must be good chrome as have already got a doggy one. Tube only needed. Can do cash or swap for bits. Thanks guys.
Kaftan, grow my hair, I wanna be a hippy cos I really don't care.........
Re: 102 longshaft drive tube with good chrome wanted
Have you got an exact measurement of the tube?
I might have one that's new old stock
UPDATE
Just looked in the darkest corners of my shed and found one. NEW OLD STOCK complete with a stud, spring and castellated nut. Bit dusty with no rust on the inside of the tube. Chrome not quite perfect as it's been sitting around for a while but VERY VERY good. Will polish up nicely. (you'll have to look closely to see the tiny marks)
24.5" LONG (or 623 mm if you prefer) shanked at both ends.
Any good to you?
Any good to you?
Sorry for the late reply Jon. Will bob into the man cave this afternoon and get the tape measure out. Many thanks.
Does your engine have the thicker tube that is machined thinner at top and bottom? That's what Jon is describing..
Hi, it is the stepped leg. As it is bolted up to the motor/gearbox I can only measure from the top of the flange at motor end to top of the geabox where the diameter slims down. It is 600mm give or take a mill or so.
Cheers chaps.
Cheers chaps.
By the sounds of things, this might fit nicely.
Yours if you want it
What have got in exchange? Any 102 bits at all?
