20 foot race boat (NZ)
Chilli Dog
Post by Chilli Dog »
A couple of people have messaged me asking about the boat I posted a picture of when I was pulling Charles's leg last week .
So here is the story behind it . the boat , not Charles Large's leg .
In New Zealand some of the organised seagull races have no class distinctions for motor or boat type , you turn up , pay homage to safety ,a small event fee and away you go . In others including the premier race on the calendar there are classes , divided by motor type , level of tune or non seagull components and boat type .
with out going to explain all history and the politics behind it , boat classes are divided into a number of groups and must meet a small number of criteria .
1 dinghy .must have at least 3.5 length to width ratio and be over 10 feet
2 Classic Bermudian .minimum length 12 ft with 3.5 ratio two person 150kg minimum
3 New Bermudian . minimum length 12 ft Max 20 ft one bow no out riggers two persons 150 kg minimum
4 Open .( any hull )
Racing dingy class as I did in my first year was fun , but being on the heavy side with body weight I was giving away to much to be really competitive , plus I was hoping to stay dry and after often admiring my friend Tinkers boat , I thought 20 footers were the way to go .
Chilli Dog Racing
Chilli Dog
Re: 20 foot race boat (NZ)
One of my other seagull buddies Adrian built a his first 20 footer out of bendy ply , a ply with the grain running mostly in one direction , makes it very easy to curve , and snap I might point out .
below is his boat .
Chilli Dog Racing
Chilli Dog
I had other ideas for a 20 footer ,and that design will be brought out for another day , but I wanted it to be dry , capable of cruising with a number on board . stable , fast and able to turn.
Adrians build method sowed the seed and with limited time I rushed together a boat of similar proportions to tinkers . these are some pictures of how it came together
Chilli Dog Racing
Chilli Dog
the bow section is soaked in water and folded and left to dry
Chilli Dog Racing
Chilli Dog
bow section
Chilli Dog Racing
Chilli Dog
bow section aft view
Chilli Dog Racing
Chilli Dog
Just join the sheets
Chilli Dog Racing
Chilli Dog
I then screwed timber to stabilize the gunnel and worked out the transom .
Chilli Dog Racing
Chilli Dog
the reason the boat is so wide is because it then meets the 3.5 ratio rule and complies as a dinghy or a classic bermudian as well as a new bermudian class so I have flexibility as to which class I run in . Though it floats on a narrow water line at rest or moving it is very inherently stable and dry
Chilli Dog Racing
Chilli Dog
turn the boat over and tidy up the joins with filler
Chilli Dog Racing
Chilli Dog
lay cloth over the hull
Chilli Dog Racing
Chilli Dog
ready to wet out
Chilli Dog Racing
Chilli Dog
wetting out under way
Chilli Dog Racing
Chilli Dog
turn back up right trim rails and fix fore deck and side decks
Chilli Dog Racing
Chilli Dog
side decks
Chilli Dog Racing
