replacing filter gauze on fuel tap
phil
Post by phil »
Just wondering if replacement is available and how it is best done.
Mark
Post by Mark »
Hi, I asked the very same question of British Seagull - their reply was that the filter and tap are integral - you can still buy a brand new tap with filter for around £25 from memory. I managed to find a good second hand one on ebay for around £11.
phil
Re: replacing filter gauze on fuel tap
Post by phil »
[quote="phil"]Just wondering if replacement is available and how it is best done.[/quote]
Thanks for your reply Mark.
I seem to recall on a previous thread that someone had soldered a bit of copper tube in place of the mesh with an end cap on it and then had drilled some very fine holes into it. Apparently it was very successful. Struck me as a good idea.
Cheers Hugo.
Vic
Post by Vic »
Thats not going to be anything like as fine as the original gauze filter. Strikes be as a pretty stupid idea unless you solder a bit of gauze around that.
phil
gauze filter
Post by phil »
Does anyone know how many holes /in. they have? Or /mm. How about gluing in a nylon one from a chainsaw? I know they turn in the 10k- 13k rpm range, and so probably have much tighter piston and cylinder clearances. Or how about the foam style filters they use in some small engines?
mrdraddy
Post by mrdraddy »
Got to agree with vic on this one, you would be better off doing away with filter altogether rather than use a bit of copper tube.
Give john a ring,i'm sure he can sort you out with a good used assembly,
you could always use a in-line filter (couple of quid from a car shop)if your desperate,i've used one on a johnson with good results.
regards paul
phil
filter gauze
Post by phil »
Thanks for the link Hugz. Phil
