Thread size in the Villiers center tube
african imp
Post by african imp » Fri Mar 08, 2019 8:17 am
I have a near serviceable Villiers carburetor, excepting that some previous owner has destroyed the thread of the lower tube that screws into the main body.
There may be just enough metal left for an engineer to re turn that thread for me?
Can anyone advise what the thread pitch is please.
The plastic fuel cup also has a hole in it, I have patched it with some epoxy which should work?
Thanks in advance.
Re: Thread size in the Villiers center tube
Post by Nudge » Fri Mar 08, 2019 8:49 am
I will find out the thread if you can measure up the plastic air intake for me.
I know the thread for the intake I just need to know the rest of the sizes so I can draw one up.
I will get the thread for you in the morning
african imp
Post by african imp » Fri Mar 08, 2019 10:05 am
Nudge wrote:I will find out the thread if you can measure up the plastic air intake for me.
Thanks,
The plastic air intake is sized 1/ 1/8" inside where the thread to the main body is, why is that size required?
The air intake size is 3/4"
Checking a similar Villiers carb and the one I used on the 102 motor to test that it would run, I see that the threaded section is on a 3/8" diameter shaft.
regards
Roy
Post by Nudge » Sat Mar 09, 2019 6:27 am
Ok, so I have no idea what thread it is... and I had a look in my "guide to world screw threads book"!
Major dia. is 8.8mm
Thread pitch is 32 tpi 60° (the other end is 28 TPI 60°9.6mm)
What I need is All of these sizes. I know the thread size so that is not an issue.
If you could fill in the gaps that would be great.
african imp
Post by african imp » Sat Mar 09, 2019 8:14 am
Nudge wrote:Ok, so I have no idea what thread it is... and I had a look in my "guide to world screw threads book"!
Major dia. is 8.8mm
Thanks with the thread pitches, I am sure that will help the engineer.
The black cowl dimentions are:
A 1 7/8"
B 3/4"
C 1/8"
D 3/4"
E 1 1/4"
Roy
Post by Nudge » Sat Mar 09, 2019 11:14 pm
Thanks
cotyledon
Post by cotyledon » Tue Feb 04, 2020 4:39 pm
HAving submitted a brass specimen ov the Villiers Air Intaks cowl to a tap and die specialist, I am advised the thread is
1-5/32" x 24 TPI - Whitworth 55deg thread form
I am further informed that if I want tap/die it will have to be individually turned for me - I didn't even bother to ask the cost !!
