Hi Folks,
Hoping one of you can give me the dimensions of the Oval Long Range Tank, in particular how wide is it?
Just rehung my rudder before ripping out the transom and installing a new Teak Transom.
Will work out all the internal blocking for the outboard before I rebuild so need to know how much room I have in relation to the rudderfor for my Century Plus and if a long range tank will fit.
Cheers Dave.
Oval Long Range Tank, how wide is it?
Re: Oval Long Range Tank, how wide is it?
Don't think it's any wider just longer but then you need a definite I'm sure you'll find the answer here china...
Thanks Tam,
It is the longer length I need to know, how much space is it going to take up athwartships. As you say the fore and aft dimension will probably be the same.
Dave.
Dave.
- fleetingcontact
350 mm x 130 mm approx
Cheers, I’ll allow 14" in old money.
Thanks, Dave.
Thanks, Dave.
