Now Gentlemen...
No, I'm not talking about tanker aircraft and fast jets doing crazy, almost sexual things at high speed and altitude....
But the principle is almost the same
Re-fuelling out on the briny is a bit of a hazardous balancing exercise over the stern,( nautical term, but blunt backy bit for some ) and getting the placcy nozzle into ( and out of) the tank as the boat is bucking around like a demon possessed, is more than tricksy never mind the fuel spilt enroute
So... has anyone had a go at converting a tank fuel cap to accommodate one of those more (ahem ahem) modern squeezy bulb fuel lines found on the 'competitors' fuel tanks that sit neatly under-thwart....(yes, that's another nautical term for those of the 'Run It In A Wheelie Bin' persuasion, not a derisive design comment on the fiddly 'Gull tilt retaining hook)
look forward to hearing any clever little japes that don't rely on 1/2 doz bent coat-hangers and copious strips of Gaffer tape (note another Nautical Reference ... crumbs, on fire today)
Neal
In-Flight Refuelling
- timberman2004
- seagull101
Re: In-Flight Refuelling
This is a common conversion, makes using an external tank a doddle. H-A uses one of these on his hot century engine. A simple drill and tap to suit the thread on the adaptor, plus you will need to drill a small hole to allow the tank to breathe and vent. Around 030" or something like that.
The other option would be to drill the cap out and epoxy a hose fitting in and push the fuel hose on and secure it with a hose clip.
- Attachments
- hose fitting.jpg (7 KiB) Viewed 742 times
- images[8].jpg (7.59 KiB) Viewed 752 times
On ebay £10.99
https://rover.ebay.com/rover/0/0/0?mpre ... 1084420215
But not fitted in the breather hole because you need that. And posibly need some sort of gauge unless you just pump till it squirts out the breather. Good thing is they dont leak when disconected.
Thats the plan im going for anyway
The Idea works like a charm!
Ive got the same setup and use it every time I go out (if you look close you can see it on my 20 footer.
