Thanks, that's a job for the morning, end of March it should be Spring up here in North East England by nowOyster 49 wrote:The thumbscrew washers are pushed into place and the the end peened over to create a burr to stop the washer coming off. Seaguls in the snow, loving it.
Where should I start
Re: Where should I start
Today was the day, new fuel added all the bolts tightened but not overtight
Wheely bin filled and Seagull mounted
I pulled the cord and it started first pull
Then it ran for a few seconds, before cutting out
I checked the fuel tap and it is set right
I checked and its pumping water just fine
The Throttle works as it should
I checked and can't see any cracks in the block
I know the fuel mix is spot on
Anyone care to take a guess?
you need to remember you are talking to someone who hasn't a clue
No grinding or rattling, it sounds just fine it started again first pull then ran for maybe a minute and cut out
could it simply be the choke, I don't know if the blade of the choke should be inside where it goes or outside
the first photo is what I mean by inside
the second one is what I mean by outside
Well done. Sounds all is in order.
The choke should be inside when you start it. Then when it starts, move the choke to the outside position.
Inside is choke on, outside is choke off. Normally choke on, then once running back it off as the engine will warm fairly quickly.
Thanks Oyster, that helped both with starting and for the future
I have it sorted now and it's running perfectly
the problem was as Hugz pointed out earlier in this topic, a blocked fuel line,
I thought I had cleaned it but after talking to a pal and reading here I took it off again
Accidently found the filter removed it and another soak in Carb cleaner I found some crud, flushed it out problem solved
I love the smell of 2 stroke in the morning
video to follow
video to follow
Sorry Gannet I missed your reply earlier, thanks for thatGannet wrote:Well done. Sounds all is in order.
Here it is running, it sounds fine to me but you are the experts
https://www.youtube.com/watch?v=RRWWIGo4Aqk
Silly question, did it gave a prop on?
Hi Keith, no I took it off, well actually I took off the spring and left the prop loose, someone earlier on here suggested it.
They probably said remove the prop, but take care not to over rev!
Some do some don't, I don't only because, I don't play with the later motors so much and you do get motors from time to time that will start and run perfectly without a prop, but not with one on, I haven't had a problem with water circulation with a prop on, so never needed to remove the prop, I think you can overrun a motor too easy without a prop.
I did slow it down, I guess it wasn't over 3/4 throttle
was it still too fast?
Excellent! I noticed your HT lead is quite close to the cylinder head. Watch out for it shorting and causing a possible problem. Enjoy using it! What you also need is a nice 102...
Haha Oyster, I can actually see me with more than just one
I will have a look at that HT lead and see if I can do anything with it
now I need to get some time off work and take the Seagull fishing
