cooling my silver centuary
My centuary plus wont put waer out of telltale, I have renewd impellor,replaced bronze bush and gear,checked inside head its clear,and water flows freely when reverse flushed can anyone help with my problem
Re: cooling my silver centuary
Hi and welcome to the forum, post some pictures of the gearbox water pump housing joint.
Any distortion there can stop the water circulation.
Is the impellor reversed?
re my sick seagull the impellor is not reversed ,i will post pics of gearbox housing joint when i disasemble it
- Stelios_Rjk
Remove the prop if you are trying with the prop on in a bin and the water level should be 1"-2" over the end of the exhaust tube.
I'm assuming the when you back flush the water is coming out of the slots at front of box and not the exhaust. If from exhaust the water pipe union is probably disconnected from block. Common problem. It is a threaded union.
