security bar
roxylass
security bar
Post by roxylass »
i have a model 75 seagull with a insulastic permanent bolt on mounting bracket.
when the engine sits in the bracket with the security bar through it there is a small gap either side so when the engine is running,
she moves from side to side on the bar, is this normal or can i fix a small washer on each side.
model no esc 181.
roxylass
Re: security bar
Post by roxylass »
sorry, model no 181 hh1.
Daryl
Re: security bar
Post by Daryl »
I wouldnt worry about it as mine has done it from new.
Taspiper
Re: security bar
Post by Taspiper »
My century has end to end play and is a bit sloppy on the pin but under steam sits still. If its shaking bad maybe it's a sign of something running a little rough? Stick some washers in if it helps.
Cheers Rolf.
www.acmeengineering.com.au
www.rolfhey.com
