FVP cases, crank, con-rod, piston
fleetingcontact
Post by fleetingcontact » Wed Mar 13, 2019 6:31 pm
All in usable condition, I've measured the main bearings and they are within tolerance.
There is a cylinder head but it seems this engine was dropped at some point because there's a chunk broken off, which I have. Maybe it can be repaired.
Sale or swap.
Gannet
Re: FVP cases, crank, con-rod, piston
Post by Gannet » Wed Mar 13, 2019 7:58 pm
HI, I am interested in the cylinder head,
I will send you a pm.
Gannet
Post by Gannet » Wed Mar 13, 2019 8:11 pm
I am also interested in the con rod. Please send me a pm.
i would like to make a record of the serial numbers on the crank cases, so would be grateful if you could make a note those down here.
Thanks.
fleetingcontact
Post by fleetingcontact » Wed Mar 13, 2019 9:11 pm
Two emails sent!
