New/unused 170/125 parts.
Post by Charles uk » Sat Dec 29, 2018 6:56 pm
I've been buying all the no longer available 170 series parts I could find over the last 20 years, many of which I realize I'm never going to use.
So I'm going to have to move most of them on.
I have, all the following are new/unused 170 parts.
Piston sets (piston, rings, circlips & wrist pin)
Main bearing pairs (top & bottom)
Crank shafts
Con rod castings (unmachined)
CDI Mk4 ignitions
Mk4 flywheels
Recoil starters
Amal 420 carb bodies & various other carb bits.
I also have several storage boxes full of used parts, trays covers, legs lower units, transom brackets.
Why not PM or email me to see if I have, what your looking for.
seagull101
Re: New/unused 170/125 parts.
Post by seagull101 » Sat Dec 29, 2018 11:06 pm
After a block for my 160...
Post by Charles uk » Sat Dec 29, 2018 11:44 pm
Cylinder or crankcase?
If it's your cylinder, how bad is yours?
Post by Hugz » Sun Dec 30, 2018 12:03 am
What is the correct chronological order of manufacture of the QB, 125/170 and 5R. Main site makes it a little unclear Thanks.
Post by Charles uk » Sun Dec 30, 2018 1:52 pm
Somewhere I have a notebook full of date data, but don't ask me to find it.
170 series first, then the Qub's, the 5R was the last of the Qub's Jan 1993.
seagull101
Post by seagull101 » Sun Dec 30, 2018 4:55 pm
Charles uk wrote:Cylinder or crankcase?
0 Compression with a badly pitted bore...
Post by Hugz » Sun Dec 30, 2018 10:01 pm
Wonder why they discontinued the cover on the top? Glad they did.
Post by Charles uk » Sun Dec 30, 2018 11:23 pm
The 170 series were styled by Terrence Conran I was told, & that was why they went to the expense of a cover, tray & all the other components that this styling required.
