Anzani Unitwin 10hp
Anzani Unitwin 10hp
Post by AusAnzani » Tue Jan 09, 2018 7:59 am
Ozzmotorz
Re: Anzani Unitwin 10hp
Post by Ozzmotorz » Wed Jan 10, 2018 4:22 am
Looks to be in nice condition.
Probably a good deal, for a collector.
Post by AusAnzani » Wed Jan 10, 2018 11:02 pm
Yep, I'd say less than 1 pound is a good deal.
Post by Hugz » Thu Jan 11, 2018 2:24 am
Arn't those ones hernia material?
Post by Collector Inspector » Thu Jan 11, 2018 12:20 pm
Hugz wrote:Arn't those ones hernia material?
Yes indeed they are Hugo.
This a ten as per the exhaust diameter into upper gearbox plate noting the casting..
I suggest that no one believes a badge. Badge engineering turning a 10 into a 15........see it all the time.
This is something someone local should investigate aye!
Indeed a 10.
Post by Keith.P » Thu Jan 11, 2018 5:11 pm
And I thought it was easier than that, the 15 had a three blade prop and the 10 had a two.
Post by AusAnzani » Fri Jan 12, 2018 1:22 am
There are in fact many small but significant differences. Not too difficult to identify when seeing them in isolation, but when side by side it all becomes apparent.
10hp 242 cc vs 15hp 322 cc. 15hp has a larger diameter bore, is substantially heavier and spins a larger diameter 3 bladed prop.
Post by Collector Inspector » Fri Jan 12, 2018 10:08 am
Of course......
