FVP and LS
seagull101
FVP and LS
Postby seagull101 » Wed Jul 26, 2017 3:52 pm
Re: FVP and LS
Postby Keith.P » Wed Jul 26, 2017 8:08 pm
Look like two early forty's and an FV.
seagull101
Re: FVP and LS
Postby seagull101 » Wed Jul 26, 2017 9:59 pm
Its a FV,LS and a featherweight, the one that looks like an LS has a LS cylinder head, FV also looks to have a featherweight gearbox.
Re: FVP and LS
Postby Keith.P » Wed Jul 26, 2017 11:18 pm
AS per thread, FVP and LS.
I always thought that an LS had a clamp that holds the drive tube to the crank case, maybe I'm missing something.
I own three or four little forty's, so I know the difference between an FV, FVP.
seagull101
Re: FVP and LS
Postby seagull101 » Thu Jul 27, 2017 9:40 am
I know very little about these little forty's, so please educate me, What is the difference between an FV and a FVP?
You may also be right about the LS or early forty.
Jacob
Re: FVP and LS
Postby Keith.P » Thu Jul 27, 2017 10:49 am
Its as simple as an FV has a small or minus gearbox and FVP has a large or plus gearbox, I don't always get it right just from a picture, I have spare FV prob and box around.
Plus I would have expected to see brass tillers on anything early and a metal fuel pipe on an LS as well as FV/P and have holes in the the gearbox not slots.
Pictured my rough LS and some props, FVP left and LS right pictured, an FV would have a three blade as per FVP style but with a minus box so it would be smaller.
seagull101
Re: FVP and LS
Postby seagull101 » Thu Jul 27, 2017 11:17 am
Got it! Thanks for that.
Jacob
Gannet
Re: FVP and LS
Postby Gannet » Thu Jul 27, 2017 5:28 pm
Yes, Keith, as I am sure that you know all LSs had the drive shaft tube clamped into the crankcase. As indeed all the F, FV, FVP, LS and LM.
The other end of the drive shaft tube, where it locates into the pump housing changed from being screwed in to a clamp bolt being used around serial number very approx. 24500
There is a lateish FV there and I suspect possibly an SJM and an SJP, but I am not certain.
Re: FVP and LS
Postby headdownarseup » Thu Jul 27, 2017 5:47 pm
I have 3 LS's, 1 early one (with screw type pumphousing) and 2 later ones (with pinch bolt attachment to the pumphousing)
I also have an FV.
All 4 of my motors have a brass tiller, HOWEVER the only motor with a metal fuel pipe is my FV.
Have a closer look at Jeremy's "little 40" list on the main site and it will become a lot clearer as for dates and things.
Re: FVP and LS
Postby Keith.P » Thu Jul 27, 2017 6:24 pm
I stated my point, I don't need to read data.
Return to “For Sale”
Who is online
Users browsing this forum: No registered users and 4 guests
