I was looking through my boxes of new Seagull spares for cable adjusters for Gannet & found 2 new Villiers Throttle cables, I must of had them for years as the writing on the bag says I paid £9.75 each for them.
If anyone needs one for £10 each + postage at cost give me a shout.
As I'm trying to cure myself of Squirrels disease, I'm going to get rid of the new parts that I will never use, over the years I've bought up several no longer dealers stock, like storm cowls, HT lead spring clips, all the carb bits, every flavour of throttle cable, I've even found a brand new complete Century transom bracket, all of which must go before I do as I'll be spinning in my grave if my heirs dump it!
I have a lot of no longer available parts, so ask the question you might be lucky!
Re: Villiers Throttle cables
I'm ALWAYS on the lookout for "old" 102 parts. (literally anything)
send me an email with what you've got
to give you some idea of what i'm after;
old style throttle levers (amal "turned up" style with the amal stamp on the top cover and the large nut that holds it all together)
throttle cables
carbs with inlet cowls
transom bits and bobs (thrust blocks mostly)
pistons/rings
cylinders
decent drive legs (not too bothered about missing chrome)
pump housings (straight out back and "sub ejector"
gearbox bits and bobs
props (all different kinds)
tiller grips
and anything else of interest?
throttle cables
pistons/rings
cylinders
tiller grips
