Early SD Bits Needed
Post your wanted adds here
seagull101
Post by seagull101 » Fri Dec 14, 2018 5:46 pm
After a bronze non inscript clutch lever and a brass non chrome throttle lever.
Need them for my new SD575.
PM me what you have.
Jacob
Re: Early SD Bits Needed
Post by Hugz » Fri Dec 14, 2018 10:20 pm
I wire brushed off the nickel on a fuel cap so l assume you can do the same to the early amal throttle lever. SD 571 is in Germany. I don't have the details for 575 do I?
Edit: that's the half one 8)
seagull101
Post by seagull101 » Fri Dec 14, 2018 10:40 pm
Yeah could do that but would rather leave a chrome one for someone who needs a chrome one. I assume it is a non chrome one i need for it???
Yep thats the one, ill get you full details once its built up, probabably by new years.
Jacob
Post by Hugz » Sat Dec 15, 2018 1:19 am
Good O. Of the 37 levers documented 34 are brass so l think that is a safe conclusion. I'll publish the updated registry soon.
Post by Hugz » Sat Dec 15, 2018 1:31 am
Couple of other things. Yours should have gearbox with nipples on starboard side and the crankcase on the tiller side should have a number... B3xxx. I wouldn't be too worried about the nipple orientation.
