EFPC Starts OK but Won't Stop
Posted: Fri Dec 15, 2017 5:36 am
by skipper20
Picked up a nice 40 Plus with clutch and recoil start today. Engine # is EFPC 398AA0. Starts fine, runs smooth and idles down nicely but won't stop. Is there a stop button hidden somewhere or does the throttle cable just need adjusting? There is a large screw head in the middle of the throttle lever assembly but turning it in either direction made no difference. To shut it off, I had to choke it until the carb flooded. Please don't tell me this is SOP. What am I doing wrong? TIA,
Bill in Seattle
Re: EFPC Starts OK but Won't Stop
Posted: Fri Dec 15, 2017 8:50 am
by seagull101
Probably just needs an adjustment.
Posted: Fri Dec 15, 2017 10:52 am
The large screw head you adjusted is just for tension, it holds the cable and stops it moving, you need to adjust the cable length, the adjuster is at the top of the carburettor, screw it down to slacken it off.
Posted: Fri Dec 15, 2017 4:14 pm
by supersaint61
the adjuster needs to be screwed down into the carb to allow the carb piston to drop lower
Posted: Fri Dec 15, 2017 6:23 pm
And then the motor will stop when throttle lever is closed and incidently, when correctly adjusted, by lifting the tiller up it will rev up a tad.
Posted: Sun Dec 17, 2017 10:31 am
It always tickles me when some one has a problem with not stopping a Gull.
Posted: Sat Jan 06, 2018 11:01 pm
by Janzip
Hi everyone,
isn`t it wondeful that someone has a Seagull that won`t stop? And that as a problem? I sure wish that I had his motor. My Seagull starts, runs for thirty minutes, then stops. I`d like to have it running, eternally!
Janzip
Posted: Tue Jan 09, 2018 10:36 am
by Nudge
Hi everyone,
Janzip
Is it getting hot? Do you have a good flow of water?
Start a new thread and we can talk about it.
Posted: Fri Jan 12, 2018 10:50 pm
by Janzip
Hello Nudge,
I´ve discussed this problem earlier, here:
"Silver Century 75 stopping during run" on the "help" forum. Please try to find it. I´ll bet on a fuel problem because I have tried, as recommended, the ignition with a spark tester, and it gives a good spark until the last piston movement. Must have something to do with the float valve not letting enough petrol through or the main jet is too small. I have now another carb, from a modern moped, fits o.k. and the engine runs o.k. in a barrel and I have a series of jets for this dell'Orto. But, as winter has come, the sea has frozen and the testing barrel has been emptied, so no possibilities for a test run until spring comes.
Until then,
janzip
Posted: Fri Jan 19, 2018 11:04 am
[quote]from a modern moped, fits o.k[/quote
One of many problems starts right there.
Simple old Gulls need simple Old Carbs........at least?
Posted: Wed Jan 31, 2018 11:44 pm
I agree.
I would refit the original carb to your seagull at least to try and eliminate certain other things before you decide the carb is the culprit here.
Start with the basics and clean everything from the tank right through to the carb. Strip the carb right down and pay careful attention to where the fuel comes into the carb and any filters along the way.
Most of the classic seagulls will have a very simple carb. They're fairly easy to strip apart and clean but often the cause of much grief if left dirty inside.
